2003 ES300 check engine light and engine vibrations
Hello everyone I was hoping to get some advice on this issue that has just taken hold of my beloved vehicle. It was driving fine until yesterday when the check engine light came on and on the way home the engine began produce some extra noise, like a vibration that you can hear from inside the car, when I gave it some gas while driving. Theres also a new audible clunking noise when given a bit of gas while already in motion. These noises DO NOT happen while in park or nuetral or even reverse. Only when in drive. They sound like they are coming from directly behind the middle of the dashboard, behind the air vents. The rattle noise is most prominent when starting from a stop and it begins around 2k rpm, its very subtle but its new and I noticed it right after the engine light came on.
Error code was checked at an auto store the next day and it came back as thermostat stuck closed or open, didnt get the specifications. Could a bad thermostat be causing issues like this? It almost feels like a motor mount is toast but its only happening in drive. I had a friend check it out and they thought it might be the cv axle going out, auto part store says that symptoms could be caused by the bad thermostat. Going to replace it asap and see if it doesnt help. Any advice? I really want to take care of this car
Hello,
Very hard to tell without knowing the specific code that you were given. Those cars don't have a code specifically for a Thermostat failure, what you likely got is P0125 - Insufficient coolant temperature for Closed Loop Control. A lot of people take it as a Thermostat failure, while in reality, this code comes up when something is preventing the ECU from going into a Closed Loop control, aka working completely off of Sensor data and not relying on predefined charts, here you can learn more about it.
Usually this code is caused by A/F sensor failure, which can be tricky to spot without the proper scan tool, here is a thread on how to check it.
As for the vibration, it can be caused by that code, so I would get it sorted before proceeding. It depends on what mileage the car has as well, since motor mounts, just like any other rubber piece, have a finite lifespan, even though they are made by Toyota, the only way to check them that Iknow of is to inspect them visually and try prying on the engine to see how far they move, then go from there.
Hope this helps and best of luck!
Lexanna (08-07-23)
Hello,
With that, it shouldn't cause the excessive vibration, that will require further investigation. I would still sort out the CEL first, just in case if I am incorrect, just be prepared that it may not be the end of the saga.
