04 ES330 just got timing/water pump replaced now has check engine light on
2nd gear
So my water pump started to leak and I got it replaced- important to not that the shop I took it to kept it for four days, continually baiting and switching me (saying I could pick it up that day then ghosting me for 24 hrs, etc). Soon after I picked it up the check engine light went on, light tester said “system too lean” and those I talked to said likely vacuum hose. I took it back to the shop, they looked at it and said every hose was fine and tried to insist the check engine light was on when I brought it (it wasn’t). Any ideas? It’s also important to note that the heat is out (has been for a while, blows cold air). I wondered if it might have something to do with the coolant/ heater core.
No heat could mean there is not enough coolant or air trapped. I suggest getting that checked before driving the car any more. Occam's razor strongly suggest they either didn't assemble the engine properly, and/or damaged something when replacing the water pump. What the specific cause is requires the car to be carefully inspected.
2nd gear
MAF sensor
Need to know what code(s) are set or we're flying blind. I think it is likely the shop damaged something.
djesky1
05-02-11 03:18 PM
djjt
06-05-06 01:04 PM
