Intermittent start issue
6th Gear
Hi… looking for some ideas on this issue…. Getting intermittent start. Cleaned air intake, replaced all coils and sparks, rebuilt fuel pump assembly (new filter, pump and pressure regulator). Ran consistent all week. Will crank and fire but won’t hold. I have a 2002 es300. Love it and first time not to start in 15 years I have had this beauty
Hello,
Where did you get all the replacement parts?
What do you mean by a Rebuilt Fuel Pump..? May be just me but I've never heard of those..
Sounds like a common issue with owners around this forum of people throwing parts on problems, which usually results in even more issues, here is a thread about it.
In short, I would put all the original parts back in, except for the pump maybe, as they tend to fail after sitting dry for a while, you may need to get a Denso replacement here. See if it changes anything, if nothing else, it will at least give you a starting point.
Hope this helps and best of luck!
C/OPN relay part number is the same for horn relay based on below links
https://www.japan-parts.eu/lexus/us/...-system#85910A
https://www.japan-parts.eu/lexus/us/...mputer/2#86530
Open the fuse / relay box in the engine bay
I believe the horn relay is next to C/OPN
Look at both, confirm they are same
Check that horn works, then switch relays. See if it solves it
swanz (10-30-23)
