Unknown leak
Unknown leak
So i recently did a oil change and while i was filling up the new oil i spotted some leakage, some out the head gasket which is whatever i have done that before and know what to do but then i noticed above the head gasket there was another leak and i have no clue what it could be, any help is appreciated!
I can't tell by your video needs to be much longer.
Looks like valve cover gasket. Haver you replaced them before? Looks like you still have factory gaskets unless someone replaced again with the black oem gaskets. Make sure those bolts are tightened, but good idea to replace the gaskets/bolts if never done or you aren't sure when it was done. Also when filling up oil it's sometimes easy for it to overfill leak on mine since that baffle always has gummed up oil impeding flow. But vid looks like top is dry and it's leaking from gaskets. Take the top plastic cover off and take another look
