window auto up
window auto up
2002 ES300. The window motors on all 4 doors were not working. I replaced the front 2 doors so far. I have the new motor for the rear 2 but have not had the time yet to replace them. When I use the auto up feature on the drivers window the window rolls up fine then goes back down 3/4 of the way. If I use only the up position on the switch it will work fine, just not the auto up. Auto down works fine. Is there some kind of programming I need to do or what?
Have you tested for the well-known over-run fault?
Hold the door’s individual button in the “up” position and then slam it a few times. This re-sets the over-run fault switch and restores full function. This is a very common problem, usually from kids playing with the switches.
Uhmmmmm🤔🙄
try this
https://www.clublexus.com/forums/es-...reprogram.html
edit: I performed this procedure recently. Here is my update
Plug it back into harness
HINT: CRITICAL - Never rotate the motor to the down direction until the installation of the window glass is completed.
- Remove the power window motor.
- HINT: Place the matchmarks on the power window motor and window regulator gear.
- Connect the power window motor and power window switch to the wire harness of the vehicle.
- Turn the ignition switch ON and operate the power window switch to idle the power window motor
in the up side direction for more than 6 rotations or less than 10 rotations (4 seconds or more). - LEAVE IGNITION SWITCH IN ON POSITION
- you can now unplug motor, install it back onto regulator
- Assemble the power window motor and regulator.
- The motor should be installed when the regulator arm is in the middle, not around the upper end (more than 50 mm clearance is necessary from the upper end).
- Align the matchmarks on the power window motor and window regulator gear when installing the power window motor.
As Oro mentioned, it is highly unlikely all four window motors stopped working collectively. The method I show is the reset procedure for the auto-jamb function on a working window motor. It does not address a non functioning motor.
HERE is a thread taking about the slam door method
Also, the search function HERE works well sourcing answers to questions that may have already been asked through the years
The car is new ish to me. Initially all 4 windows would roll down. Sometimes they would roll up but most times not. The fronts go up and down now after motor replacements. The passenger side auto up is working normally. That motor was replaced at a shop. The driver door goes up and down but auto up goes up and then goes back down about 2//3 rds of the way. I have to use the up only not auto up. Both rear windows will not roll up at all without me helping the glass. I have new motors for those also I just have not had time to change them yet. I wanted to figure out what I did wrong on the driver door before I tackled the rear 2.
Driver rear window is working all the sudden. I have no idea why. Passenger rear is still not working. When I try to put the window down. There is a light flashing what appears to be a code on the rear window switch. It does a double flash and then pause. It does it for a few seconds then the light stays on solid.
Hello,
This usually happens when the window looses Home Position, meaning that it doesn't know where its limits are. There is a good number of threads on blinking Window Switch, here is one of them, you can also try lowering the window, then holding the switch to Auto Down for at least 3 seconds, then raise the window and hold Auto Up for at least 3 seconds, and see if that helps.
Hope this helps and best of luck!
Ok. I am finally sitting in the car at home for a minute.
Down and auto down works fine. Up works. Auto up is freakin out. Auto up from all the way down goes up 1.5 inches then down. If I use up it will go up and stay. If I hold auto up then let go after at least 3 seconds it rolls down most of the way.
