92 es300 - is it over for me?
#32
Get this one....
1993 Camry 3VZ-FE Automatic Transmission ECU "good working order"
Or do a search for 1993 Camry V6 ECUs which are still working OK... I can verify a 1995 Camry 3VZ-FE ECM works in a 92 Lexus ES300, but the gear changes are ever so slightly lazier.
Camry 3VZ-FE Engine Computers
#33
Hello,
It's been a while. And I finally got some good news and some bad news too...
So I was able to solve my problem - picked up an ECM from a 93 3VZFE from a local junkyard, and upgraded it with Japanese capacitors.
It looks like previously I had bad luck finding an ECM that would still be salvageable and that's why I was having a hard time figuring out the problem.
By the way, this thread helped me finding a compatible ECM - https://www.toyotanation.com/threads...bility.374547/
Then I was only able to enjoy my car for less than a week and on my way back from work I noticed white smoke coming out of exhaust.
Checked oil and coolant and it was obvious that I had a blown head gasket on bank 1.
Anyway, this concludes that.
By the way, if anyone's interested in practicing their soldering skills - DM me here, I can send you my ECM and/or AFM for the cost of shipping if you're located in Canada/US. Or we can meet in person in Vancouver, BC / Seattle, WA.
There's a good chance this AFM can be saved - I was gentle when I pulled out the harness.
Plus I will include capacitors from Digikey with an ECM.
Just don't want to throw all of this in the trash.
#34
What's the plan for the car if you don't mind me asking, it's a pretty well known problem for those, should be relatively easy to fix if a bit expensive, seems like there's still life left in that car after all..
Well that's a bummer, sad to see another ES succumbed to a head gasket. Either way, thanks for getting back, at least one of the issues got resolved..
#35
(Edit - Just realized the IACV question is now moot with the blown head gasket. Bummer. Never mind).
FWIW, I just CLEANED (rather than replace) my likely original IACV in my `98 3ES. It had been gunked up and stuck in an open position (a fixed orifice?) for years. Once cleaned, my car's ECU got confused and things got really rough around idle speeds.
Unplugging the battery long enough to reset the ECU got things right again.
What does this mean for your '92? I don't know. But unless your ECU is functional, an OEM IACV (Aisin is likely the closest you'll find new - they're a key Japanese OEM supplier to Toyota) will never be put to proper use.
This video to rejevenante an old dirty IACV:
#36
At the end of the day, I'm paying for the head gasket problem either way - by selling it with a huge discount or by fixing it myself.
And since I got two other cars that are special to me, I just don't want to spread my resources too thin.
LS400Eddo
65
05-08-21 08:50 PM
WetBrain
Performance & Maintenance
13
07-18-12 02:42 PM
