2001 Lexus es HELP! Lock cylinder busted out!
Looking for help I have 2001 Lexus ES300. Someone tried to steal it and dug out the ignition lock cylinder. So I actually got it started to where it stayed running for like 30 minutes and then I cut it off, the key will not stay in ignition but it stayed running. However every other time I have tried to start it it will just start and go dead while I’m holding the key in. Wondering if there’s any trick to getting it to start and stay on,until I can order the new cylinder and everything.Like I said I have the key and immobilizer. Thanks!
Hello,
A picture of the damage would be helpful.
If the car starts at all, then the Immobilizer is working, all I can think of, if it is indeed related to the Ignition Lock, is a contact being lost somewhere. As a temporary fix, you can take the entire Ignition Lock Cylinder out and use pliers to start the car for the time being, but again, hard to tell anything without seeing it..
Hope this helps and best of luck!
Hello,
Hey thank you so much and I will send a picture I have now removed the cylinder and gonna see if it’ll start and stay running. Another question you maybe be able to answer.. If I change out the cylinder I’ll have a new key but if I was to switch the insides of the key generally speaking it should work right?
This has to clipped on right or it won’t start at all just crank but if this is on and my key is in the right place it will start for a minute and die, prior to me removing the cylinder. I haven’t tried to start it since removing, I will update the post after I do. Thank you so much for helping
Yes, if you swap the Old transponder into your New key, the car should start.
The black ring you were referring to is the Reader Coil that reads the signal from the Transponder, without it, the Immobilizer won't allow the engine to start, as it won't see the signal from the Transponder. To start the car with pliers, you will have to have the key near that coil.
That said, after the Ignition is turned to the On position, the Immobilizer stops requesting the information from the key, as it already made a decision on whether to allow the engine to start or not, meaning that you need to keep the key near a coil only until you turn the Ignition to the On position, afterwards the car should start even if you remove the key completely. All that is to say that even if the key moves away from the coil, it should not make the car stall, there is something else at play.
P.S. What a carnage for an arguably pointless endeavor, what is the point to stealing a 23 year old car is beyond my understanding.
Installed ignition
As stated before, Neither the Key, nor the Immobilizer System in general have anything to do with it stalling over time, Immobilizer shuts of Both Injectors and Ignition, the car will not start at all, no matter how hard you press the Gas Pedal. More than that, the Immobilizer inquires about the key only Once, when you turn the Ignition to the On position, after that, you can throw the key out the window and the car will keep running, just like the Push to Start cars.
We have no idea what happened under the hood of a car, so there is no way to eliminate a Mechanical Flaw at the moment. Get a Scan Tool and check Engine Live Data to see how the engine runs in general, and what causes it to stall, check both Long and Short Term Fuel Trims (LTFT & STFT), MAF Sensor Readouts and Ignition Advance, LTFT & STFT should be as close to 0 as possible, MAF should show about 3.5 - 4g/s, if it is Less, you have a Vacuum Leak, Ignition Timing should be 10 or 15 degrees at Idle. Start from there and see where it goes.
https://www.youtube.com/watch?v=jSum3om2oYI
luckystar
04-25-21 12:58 PM
mkivmattho
08-27-12 09:14 PM
