2000 ES300 AC Out
2000 ES300 AC Out
So curious, any Lexus/Toyota I've ever owned the AC has never gone out. Current situation is when the AC button is pressed, there is no "click" under the hood turning on the compressor. Checked fuses, all is good. Any ideas greatly appreciated.
Hello,
Here is a thread on how to enter a Diagnostics Mode for the Climate Control, see what codes you come up with, more than likely you are just low on refrigerant from the leak in the system, if so, fill it back up with UV dye to find the source.
Hope this helps and best of luck!
jbl-1985 (05-06-24)
