third brake light bulb burnt out
Old 08-14-05, 12:49 PM
RCL
RCL's Avatar
Photo 3 showing housing locating guides and retainer clips.
There are two #921 bulbs inside the housing.
Old 08-19-05, 07:12 PM
2K95es300
2K95es300's Avatar
Good job RCL.
I had to change mine earlier this year and had the same issue of not being able to remove the unit. I used two curtain rod hangers and slipped them under the assy about 1/4"-1/2" in from the corners. I then used a couple of pliers to pull the assy out of the mounting,
As you can see from the above photos, you just push the assy back into place until it snaps.
NOTE: This assy also needs to be removed, if you want to replace the rear deck speakers.
Old 08-19-05, 08:20 PM
Spyder187
Spyder187's Avatar
Originally Posted by 2K95es300
Good job RCL.
What is the assy? I still haven't been able to snap mine back into place. Have used some clay there temporarily to prevent it from sliding.
I do have about if not the same setup as the above picture but the thing just will not "click" back in.
Old 08-20-05, 07:08 AM
2K95es300
2K95es300's Avatar
Assy = Assembly (the collection of parts that makeup the third brake light assembly (ie. clips, bulbs, socket assemblies, lens, plastic housing, etc.))
Make sure the assy looks like the one posted (has all the parts and placements), then align the assy flush on the rear deck. You should now be able to slide the assy back into place and feel a hard snap as it pops into place against the window.
Old 08-20-05, 07:19 AM
2K95es300
2K95es300's Avatar
The clips (circled here)...
Old 08-20-05, 07:22 AM
2K95es300
2K95es300's Avatar
snap into the holes (circled here) into the deck of the car.
Last edited by 2K95es300; 08-20-05 at 07:27 AM. Reason: Image didn't upload due to size
Old 08-20-05, 07:36 AM
Spyder187
Spyder187's Avatar
Thanks RCL and 2K95es300 for posting up the helpful pics.
My assy, , has the same retainer clips and stuff but it won't "click" back in. I'll take some pics when I get back from my one week holiday and hopefully someone can help point me in the righth direction. Cheers guys..
Old 10-27-07, 10:35 AM
jetman65
jetman65's Avatar
Smile Easy Fix
There is an easy fix to getting the cover off the third brake light. I have a 1995 ES 300 and there is a hole under the third brake light that you can stick a phillips screwdriver in (stratight up) and pry the cover towards the front of the car. I had my cover off in 30 seconds and went on to replace the bulbs.
Old 10-27-07, 11:20 PM
BadViper22
BadViper22's Avatar
Holy thread revival Batman! Ummm, odd, most people introduce themselves first. But let me be the first to say...
Welcome to ClubLexus!!!
And welcome to the ES forum, this is positively the most tight-nit group on Club Lexus, enjoy your time here!
Old 10-28-07, 04:37 AM
Choas
Choas's Avatar
^Holy old thread indeed. Well to CL anyways and pics please
Old 04-17-12, 05:36 AM
chuckerst
chuckerst's Avatar
Many posts about this-some just wrong for a 94 ES300-whoever said unplug the wiring from the trunk..can't be done on mine-whoever said take the package tray out first-WRONG!-Won't come out until the third brake light housing is off-whoever said use paint can openers and pull it towards you--RIGHT! I used two allen wrenches and pliars-popped right off-bulbs went in easily-snapped it back on-5 minutes total!
Old 04-18-12, 11:13 AM
eyezack87
eyezack87's Avatar
Holy thread revival! I do have a DIY floating around here on the forums saying the correct way to do it though
jonathanrn
RX - 1st Gen (1999-2003)
01-10-18 08:24 PM
jboy
Suspension and Brakes
01-22-14 01:20 PM
RX300Scott
01-18-11 09:56 AM
darkangst
08-09-10 04:54 AM
infra917
IS - 1st Gen (2001-2005)
02-23-07 05:56 PM
Quick Reply: third brake light bulb burnt out
