My connector is shorted from previous accident.i stopped at parts store but the 2 pin connector they had was to small to handle that fan.
What's the cheapest connector with pig tails?
Should I just solder it together? Since I just replaced the radiator it's unlikely I'll ever remove it again at
240,000 mi.
Here is a thread on how to de-pin a connector, if your pins are still intact and it's just the housing that is snapped, take said housing from any local junkyard and assemble it on your car, you won't have to cut any wires. If the pins are damaged, get Crimp Connectors (here is a link), then the same connector assembly from any junkyard, and splice the new terminals back in, while not as pretty, it's just as durable.
