2004 Lexus es330 wiring issue
So I just swapped out my entire ignition assembly (ig switch, lock, etc) and when I was reconnecting all the wires and putting everything back together, I noticed 3 of them in particular that I couldn't seem to find where they connect. And of course when I went to test out my new ignition, all the lights came on in the car but when I actually went to crank it, silence. No clicking or anything. Complete silence. And I'm guessing it's because one of those wires might connect to the starter but I'm not 100% sure. I'm going to post pics of the actual wires though so you'll know exactly which ones I'm talking about.
This one looks like it runs to the fuse box and I thought it plugged into the back of the lower dash panel but I didn't see where it could go
I'm pretty sure when I took this off that the wires were running to the bottom center hole, but I have no idea
This is the second one. As you can see, it runs to the gear shift box (as far as I can tell). Normally it would be safe to assume that it would connect to the center panel but nope
There's already a different set of wires that connects to it and I don't see any other places to connect it
And this is the last one. I'm almost certain that this one has something to do with my A/C but it doesn't fit any of the slots on the back of the a/c control box. Oh and if you couldn't tell, this is a hose, not a wire
Any help or insight you could offer would be greatly appreciated. This thing has been stressing me out lol. Oh and if you need any additional info that I may have left out then please just ask and I'll do my best to provide you with whatever info you require. Thank you!
