4ES Driver's Power Window Issue
5th Gear
Hello, I have a 2005 ES330 and am having trouble initializing the one touch window feature, specifically for only the driver's window. I have searched through the forums and performed the battery disconnect and initialization procedure a few times. That being said I may have done it wrong, there are conflicting reports on how long to hold the switch after the window has reached the end of its travel, I've tried everything from 1 second up to 6 seconds. All the other windows' one touch feature works and I can confirm the driver's switch LED is still blinking.
One thing I noticed is that both window down switch positions will open the window, but only the farthest window up position will close the window. I am wondering if anyone else has experienced this, I'm thinking maybe something is wrong with driver's window switch if one of the positions isn't responding. Any help would be greatly appreciated!
