04 Headlight bulb options request
Hello
After a VIN verification, my 04 has Halogen high beams and HID low beams.
Both are worn out, in need of replacement
For the high beams I am going to go with the Luxster Punisher 2024. Anyone use these?
For the low beams I am not decided on an HID company / brand.
What have you use for super bright light - 6K ?
thanks
H2
thanks
H2
Luxster is a highly rated bulb you should be happy with it. For low beam I'd go with thiese
https://www.hidconcept.com/en-ca/col...ulbs-pack-of-2
Not saying to buy from that site necessarily but be very careful what vendor you use there are loads of fake bulbs. FYI for HIDs the higher the colour temp the lower your light output this isn't the case with LEDs. I prefer 6000K some people insist on ~4500K.
Hello,
Here is a good place to get the bulbs, both Low and High beams. I've had those Phillips D2R bulbs installed in my 2000 ES300 for about half a year now, no issues so far, work better than my beat up OEM bulbs with over 200,000 miles on them, if that helps at all..
Hope this helps and best of luck!
details please for clarity.
DRL as part of the high beam circuit prevents most LED bulbs from working without a "cancelling" module. Which one did you buy exactly?
