How do I increase my horsepower? 98-ES300
What is the best way to increase my stock horsepower for my ES300? In addition, I want to start adding to the engine starting with my exhaust..then what? Any information would be great!!!
Originally posted by FLiP Sp33d
trd camry supercharger! it should work.
for the $4000 price tag +installation it only produces about 50 hp at 6psi to the wheels
with $4000 + installation i could do a bs turbo setup and make more hp at higher psi
custom turbo > trd supercharger
The supercharger can be found for 26XX new at www.toyotaparts4u.com it is the most reliable way to boost the 1mz. It also has an electronic boost control so that the first gear doesnt get boost. The jp headers, y-pipe and cat-back should fit no problem check this site- www.jpperformancellp.com call and ask jose if it would fit. Their is now a REAL cold air intake being made by danny from www.solaraguy.com http://www.zer0.info/solaraguy/viewtopic.php?t=6375
This is a package that URD has put together it includes most of the stuff that is reccomended when you go to more boost with the smaller pulleys that are available. http://www.urdusa.com/Merchant2/merc...Category_Code=
On that page you can see what the jp headers look like on the car.
Keep in mind that the es300's with vvti are not going to be able to be supercharged due to the dual throttle bodies. So basically you can-if money permits supercharge an es300. And with everything here you will be putting done about 250-270 hp to the wheels.
Just incase someone here want to Turbo charge their ES300 ...http://performance.narcs.net/1mzfe.htm
for TRD S/C... with A/T u wouldnt feel extremely fast... but more smooth...( since i got a chance to test drive a S/C'ed camry), if i got the money.. turbo it all the way...
I talked to someone at Rod Millen a year ago or so (when i was considering getting a 97-99 ES) about performance options, and I mention the TRD supercharger for Camry and Solara. He said it should bolt up, however electronically it wouldn't work because of the VVTi. He said its a very complicated system, and unlike with Honda's VTEC, tuners haven't really been able to crack it because of the complexity.
Also.... does anyone have sound clips of an ES or Camry/Solara V6 with exhaust, i'm extremely eager to hear what it'd sound like!
I've seen overboost kits for the TRD S/C that take it to 343 HP at the crank, which is almost as much HP as the old body style E55 AMG! (and more than an E46 M3!). Yes, I know that that would require many more changes (completely rebuilt auto tranny, those numbers would destroy the stock auto in short order), better headers/exhaust. But imagine a 343 HP 97-98, in that dark indigo blue color, with OEM wheels!
