Transmission not shifting correctly:
Hi everyone,
I have yet another transmission concern I've noticed over the last couple of days & just wanted to run it by you to see if this is normal or if I should take it to the dealership to have it looked at.......sorry if I'm getting on some nerves here with asking so many questions (quite a few about the maintenance of the tranny as well) but please bare with me. I'm still learning about the ES as I go here. Here goes...
- When the car is cold & has been sitting over night outside (I work nights & can't park it in doors) the temp is between 0 c (32 f) & - 18 c (0 f). I would start it in the morning & let it idle for about a minute to a minute and a half, I start to drive under VERY light load, I find the RPM's extremely high when it shifts from 2nd - 3rd gear (fairly high when shifting between 1 & 2 also but a lot more noticable on the 2 - 3 gear change. I am doing between 16 MPH (25 kph) & 30 MPH (50 KPH) but the tach is about 3,100 RPM during this time & as I said I am accelerating very slowly to get up to this speed & it takes a good 20 - 25 seconds for it to shift to a higher gear to bring the rpm's down to a more normal level (I am aware that because the vehicle is cold it usually rev's higher while warming up). My question to everyone is, does anybody think this is a little excessive & should take this long before it shifts into a higher gear? or is this just perfectly normal operation of the transmission? Could it be that something is not quite right with the transmissions computer & needs some sort of an adjustment or recalibration? & do you think it's serious?
Once the vehicle has reached "operating temperature" all seems fine & normal.
I don't recall my 01' Maxima taking this much time when doing the exact same thing I described.
I plan in the next couple of weeks to do a complete transmission flush, but I think I will hold off for the time being to see if I should have this problem looked at by my Lexus dealer under warranty. Any answers, advice or suggestions would be helpful, thanks everyone!
The delayed shifting when cold is by design. I remember this happened with my '94ES when I bought it new and I also thought there was something wrong. I noticed that when the temp gauge moved up to the cold mark(1st. mark) everything then shifted normally. My Lexus dealer also confirmed my findings.
xcamryman
08-18-06 11:24 AM
