High RPMs in morning?
Perhaps it's just because the car has been sitting overnight, but I'm not sure... When I go to start my 1997 ES 300 in the morning the engine revs up to 2k rpm and sounds like it's racing. It doesn't subside until I put it in Drive or Reverse, and then when I park it it goes down to its usual idle of 750 or 1k. Am I just paranoid, or does this seem a little weird?
Zach...I have a 2000 ES and it does the same thing. I suspect that the idle is electrically controled until everything warms up a bit. Does anyone know for sure?
Re: High RPMs in morning?
Many Lexus products do not "clunk" or jolt when you shift from Neutral to Drive at fast-idle RPM like some other cars do because of the "Shift Shock" control....this feature, unlike cheaper Toyotas, momentarily, for a split-second, grabs high gear instead of first, then grabs first. By doing this you get much less of a jolt.....in my IS300 you cannot feel it at all. It's just one of the nice features you get when you spend the extra bucks for a Lexus.
Okay, thanks for the great replies. This is happening in Phoenix, though, where the morning temperature is like at least 65 or 70 degrees F. I just thought it was a bit odd. I haven't let it run for a couple minutes, but I'll try that tomorrow morning and see how it is.
Thanks again!
Thanks again!
Thanks again!
Thanks again!
That brings up another point many people ask about. When you DO have the defroster/AC compressor on, you have to ad a little heat to keep the front window from becoming chilled by the AC blowing cold, dry air on it. When that happens, then you get moisture condensing on the outside of the glass and you have to use the wipers. A little heat added to the defroster will prevent that from happening....and ALWAYS use the fresh-air mode in defrost....NOT the recirculate.
it is not really a question of the temperature of Phoenix as it is a temperature of the coolant, exhaust gasses, oil and air/fuel mixtures that determine the rpm and the length of time that the engine revs high.
For emissions purposes, the car will run in an open loop until the certian air/fuel/coolant temperatures are met, then the engine runs in a closed loop and the rpms drop to the normal idle.
mmarshall also brings an excellent obsevation to the table.
steviej
steviej
The warmer the ambient temperature, the quicker the engine will come up to operating temperature.
It stands to reason that bringing a cold engine from about 30ºF to operating temperature will take longer then raising a cold engine from about 70º to operating temperature. Am I correct in this assumption?
Agreed I asked pretty much the same questions on this issue zach with regards to my 01. More experenced members assured me that this is normal & I don't even think about it now Just takes some time to get used to the car & how she is designed to operate as this is my first Lexus (Toyota) product. Not my last to be sure I might add
Originally posted by steviej
zach, its normal. Emission controlled to warm the car up faster. You will also notice that on cold mornings that is revs higher before it shifts out of 1st and out of 2nd. It all goes away as the car warms up.
steviej
steviej
This is not necessarily the tranny cold-shifting at higher RPM but giving the impression of doing so
Originally posted by amf1932
The delay in transmission shifting when cold was purposely designed into the operation of the ES's. This is controlled by the engine computer and NOT by the thickness of the lubricating fluids.
Sorry if there was a misunderstanding there.
