Changing license plate bulbs?
Originally posted by HoeBag
um.. havent done it in a long time, but there should just be one screw underneath and itll pop right off... if you look at it you can figure out how to take it off, its not hard at all
if i remember correctly one side pops off... but my memory is kinda fuzzy... um.. all i can really suggest is playing around with it
Originally posted by ES3
Doesn't appare like anyside pops off, there's a plastic bolt that comes out but the casing seems pretty tight in place, do you know if you have to remove the pastic molding that lines the top of the trunk?
im sure you dont have to go through the trunk to get to it.. its all exterior work... if i have time tomorrow ill go see how it comes off
Here's how you do it (on the 2nd-gen ES)
Use a small flathead and carefully pry out around the outer circular plastic cover beside each of the 2 license lights, which basically holds the license plate light assembly in place with the trunk lid. As I expected, the circular pin is like the plastic clip-style screws found on the inside of the trunk covering when accessing the tailights.
Here's how it looks like in my 2001 ES300. The bulb type is 2825; it should be the same on the '97 ES.
A closer look of the license plate light itself (sorry for the blurriness)
To remove the bulb, simply unclip the electrical connector, twist/unlock the grey plastic socket which holds the bulb, and pull the wedge-based bulb out. Hope this info helps.
London Bill
SC- 1st Gen (1992-2000)
376
08-23-15 04:06 PM
