Door panel removal-92 ES300
I have seen a lot of posts for door panel removal, but can't find one for a 92-93 model,
rear door. My window is down. Can someone help with this ?
Its very easy to take the door panel off. Its gettign it back on right thats tricky. make sure you un screw all screws on the door. one is covered by a round plastic thing that you can only see when the door is open and there is an other screw in your door handle. Just pop off the cover that hides it and un screw. once you get all screws out then starting at the bottom of the door slowly pull the doo panel to you poping out the plastic clips that hold it in(don't lose them).. once that is done Pull out the inside door handle cover and push the panel up so the panel lip clears the door and pull out. Then disconect the wires to you windows and you should be good to go. If this is what you are looking for then here you go. Hope I didn't miss anything.
nawh sounds like you're right on the money
DixonPai
05-31-09 04:00 PM
