My 1st oil change experience (long)
Old 04-16-07, 06:31 PM
  #31
92ES5sp
92ES5sp's Avatar
Cool
I dont have pics but you cant miss it; its the 14mm bolt at the bottom of the oil pan.
Hey Lexusk8, I know this synthetic VS. non-synthetic debate was kinda old but if it makes you feel better, I got my ES 3 years ago with 58K on the clock. First oil change was Castrol Syntec and will use it the rest of the cars life. She now has 100K and is bone dry under the hood. I really dont think switching to synthetic oil will cause problems if the engine has had regular oil maintenance, which by reading your posts I can tell you perform all maintenance on time. I know my mileage is kind of low but its been said that time, not mileage will deteriorate gaskets. Well my valve cover gaskets and rear main seal are 17 years old and leak-free
Old 04-16-07, 10:34 PM
  #32
3000
3000's Avatar
Originally Posted by Wald GS
Can someone please post a pic of the oil drain plug? thanks
Oil drain plug granted:
Old 04-16-07, 10:35 PM
  #33
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Thanks soooo much!!
Old 12-27-13, 02:05 PM
  #34
gtstcactus
gtstcactus's Avatar
Hey guys, going to do an oil & filter change on my 92 Windom... Is a bottle jack which will raise the car by 32cm going to be enough height raised? (i've got stands, but they are only as helpful as high as the jack can go...)
Old 12-27-13, 05:30 PM
  #35
gtstcactus
gtstcactus's Avatar
Is that pic for a 2nd Gen ES??? (92-96)
Old 12-28-13, 04:37 PM
  #36
Hayk
Hayk's Avatar
You can do an oil change with the car on the ground, so that should be sufficient.
Old 12-28-13, 04:47 PM
  #37
amf1932
amf1932's Avatar
You can change the oil on the ground, but I found it easier if you have ramps. This way you drive up the front wheels up on the ramps and you have plenty of clearance to put an oil drain pan underneath, and also room to remove the drain plug.
Old 02-10-14, 08:34 AM
  #38
Trugr8ns
Trugr8ns's Avatar
So has the synthetic vs non-synthetic debate now been concluded? LoL!
Old 02-10-14, 09:52 AM
  #39
BDSL
BDSL's Avatar
Do NOT get under the car without jack stands......This is for your own safety!!!!
Old 02-10-14, 11:38 AM
  #40
gtstcactus
gtstcactus's Avatar
If that was for me I did use jack stands... 2 even, and the jack in position!
Old 02-10-14, 12:03 PM
  #41
BDSL
BDSL's Avatar
I also have been doing oil changes with the car on the ground for many years....if I can.
Old 02-10-14, 12:54 PM
  #42
mcomer
mcomer's Avatar
Understand the lack of photos, sounds as if you would have burnt/drowned the camera during the DIY session. Maybe next time?
Old 05-15-15, 10:41 AM
  #43
Jeepero13
Jeepero13's Avatar
Thanks for the link, very useful!
Old 01-12-16, 12:46 PM
  #44
Jaggernaut
Jaggernaut's Avatar
Originally Posted by amf1932
As far as spilling the oil, you should treat yourself to a big catch pan that you can buy at almost any auto supply store.......this way you don't have to be so accurate when placing the pan while draining the old oil.
A large cat litter pan works well also. It'll only set you back roughly $3 from Walmart(devil's playground).
Old 01-14-16, 12:33 AM
  #45
artbuc
artbuc's Avatar
If you were able to collect old oil in a 3 qt container you have a problem. I suggest you check oil level every 500 miles until you have confidence you are not burning/losing too much oil.
Quick Reply: My 1st oil change experience (long)
