Brakes Squeaking
I just had my brake pads replaced at a Toyota dealer with OEM Camry crossed referenced pads. They still squeek at a certain point in braking, usually at light press of the pedal. Same as before it was replaced. There's no warranty on it either said Toyota. The rotors look alright to me. I also tried spraying brake cleaner on it, still the same squeek.
Lexus Connoisseur
Did you have your rotors turned?
Lexus Connoisseur
Originally posted by Booner
No rotors turned, that would of been almost $250. And that's why there's no warranty.
Originally posted by flipside909
You could have gone to an independent mechanic to get your brake job done granted you bring in the genuine Toyota pads and have the rotors turned for way less than $200.
I just might go to one and have them rotate it, the squeeks and squeels is getting worst.
Lexus Connoisseur
That's interesting. You should have him take off the rotors and inspect your axles and etc.
08-27-15 06:18 AM
liquidx
Suspension and Brakes
09-09-10 05:56 AM
