Clunking noise while releasing brake pedal on ES330
Originally posted by mmarshall
Apparantly in your case it was a strut, but not all Toyota/ Lexus products have struts per-se. The IS300, for instance, has a Honda-type double-wishbone front end...but still gets that clack noise from the brakes.
Guess each car has to be dealt with individually.
wijacket: when in doubt, go back to the dealer and get behind the wheel of a loaner ES330 or one on the lot and bring the service manager with you. Show him the noise in your car, then go drive another ES330 and see if it does the same thing. If it does then made it is inherent in the design. If it doesn't, yours needs a closer look.
steviej
