Tools I used for this replacement:
3/8" Ratchet
3/8" Electric Cordless Impact Wrench
3/8" Extension
3/8" 12mm Socket Deep
3/8" 14mm Socket Deep
3/8" 14mm Socket Short
Note:
For the ES300 years 1997-2001 this will not be an exact DIY but it will be very similar.
Factory Part Number: 12363-20020
If you can swing it, installing ARP extended studs onto new rear wheel hub/bearing assemblies is worth doing to install spacers in the safest manner. It took me my trusty $110 Harbor Freight impact gun, a hammer, and the correct ARP studs. In this case, Detroit Axle (manufacturer of the new hubs I installed) utilized stock studs designed for Civics and Integras, so I had to buy ARP's 1007711 kit. I then hammered the studs out of aftermarket 20mm wheel spacers (20-25 is the sweet spot) and installed them, using the stock chrome lug nuts.
PROTIP: Just put the studs through the splined holes, for less play, rather than how I did it in this photograph.
Hey there! I am looking for help on my lexus es330! Does not start, no crank whatsoever. i’ve gotten both the battery and starter tested, as well as replaced the whole fuse block, neutral saftey switch, the ignition switch, and starter relay. any suggestions or similar experiences?
Hi all, I’m new here. I need a service manual for a 2000 es300 3.0 engine. Blown head gaskets, doing the work myself.
is there a pdf version available? My email is bruceboege@gmail.com
thanks for any help!
However, this link is 360 pages of all electrical circuits in the lexus. I've never seen such detail for a car. But, this is not useful to my job,
I need that kind of detail for the engine, Teardown and reassembly for head gasket replacement.
Di I just ask on the Mega site? I joined, made an account.
If you have a link handy, send as you did the other one please!
My name is Chris Mockridge I have 03 Lexus es300. I started getting multiple cylinder misfire coads and car was running rough. It reminded me when I first got the car it did same thing but quickly figured out the previous owner had quick release on positive battery cable. After fixing it it has ran perfectly for a year. Now I started with injector cleaner and it seemed to clear up slightly but still not right. Next I took fuel pump apart replacing fuel filter, and strainer in the tank. Still not right. After that I changed all the spark plugs, and tested coils with ohm meter, then started cleaning electrical connections to alternator. It's super close but still sputters a little, and is throwing cylinder 3 and 4 misfire, or multiple cylinder misfire. Any suggestions? I'm going to start going through every wire to coils now. Thanks for your time.
Hi I’m new here and I’m not sure where to ask about this but my rear passenger tire is leaning inward to the top and making a clunking and grinding noise when I hit bumps or turn can someone tell me which parts it is that I need to buy to fix this
