ES330/300 DIY (do-it-yourself) & technical tips
#196
There is a "sock" filter as part of the fuel pump, no fuel filter under the hood. What makes you think the filter is clogged?
#197
#198
I spent somethin like 5 bucks on this via eBay but i figured I'd post it on here for free in hopes you guys might be able to return the favor with my GPS installation!
Remote Keyless Entry Programming Procedure
(Customer Program Method)
1. Sit in the driver's seat and lock all the doors.
2. Unlock and open the driver's door.
3. Insert the key into the ignition and remove it (don't turn it...just remove it).
4. Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
5. Close the door.
6. Open the door.
7. Lock and unlock the driver's door 5 times (with the power switch).
8. Insert the key into the ignition and turn it to the "ON" position.
9. Remove the key.
10.The driver's door will now lock and unlock itself one time.
11.Press and hold the "LOCK" button on the key fob for at least 1 second.
12.Close the driver's door.
13.Open the driver's door.
14.Press and hold the "LOCK" button on the key fob for at least one second.
15.Close the driver's door.
16.Press and hold the "LOCK" button on the key fob. The door will lock.
17.Press and hold the "LOCK" button on the key fob again. The door will unlock.
5. Close the door.
6. Open the door.
9. Remove the key.
My owner's manual makes mention of various features which can be programmed by the Lexus dealer (such as auto door unlock with ignition off). Why can't we do this ourselves?
Stomp your feet, rub your tummy, turn around and clap three times!
Why isn't there a device much like a auto analyzer which plugs in to the maintenance port?
LexFather
04-23-13 10:55 AM
The Ikon
SC- 1st Gen (1992-2000)
16
08-12-01 11:59 PM
