ES330/300 DIY (do-it-yourself) & technical tips
Old 06-07-08, 09:21 PM
  #61
VIP_ES300
VIP_ES300's Avatar
thinking of putting fogs on my es...
Old 06-15-08, 01:59 AM
  #62
kiwies300
kiwies300's Avatar
I just tried to debadge my 92 toyota windom only to find holes under the badges 4 under the windom 2 under the 30 g badge .
bummer
I will fill the holes from the underside of the boot lid.
are there any other windom quirks i need to know about ?
Old 06-17-08, 02:10 PM
  #63
lcwizzzel0
lcwizzzel0's Avatar
but 20s will fit at least on an 01 es300 check out my avatar
Old 06-23-08, 12:34 PM
  #64
kphu
kphu's Avatar
Default How to by pass 92 - 96 ES300 amplifier
Here's the wiring diagram for the amplifier on the 92 - 96 ES300.
What you'll need to do is run speaker wires from your head unit to the corresponding speaker cable of the amplifier. Cut the speaker cable and connect it to the end that's not connected to the amplifier harness.
Attached Thumbnails ES330/300 DIY (do-it-yourself) & technical tips-es300speakerwiringdiagram.jpg
ELForce (10-14-20)
Old 07-15-08, 06:21 AM
  #65
Tripnbeats
Tripnbeats's Avatar
how about the automatic window feature?? i had my ES broken into and the body shop never adjusted the window to stop in position at the top....so when the window closes it senses that theres something stopping it and it goes down as the obvious safety feature. thanks for the help
Old 07-19-08, 01:24 AM
  #66
DRACO A5OG
DRACO A5OG's Avatar
Thumbs up 96 ES300 P0401 Trouble Code Reset & Fix DIY
Hello Everyone!
Newbie here working on my lady's 96 ES300. I'm a Modest Experienced DIY 911 Guy and decide to DIY hers.
I read a bunch of threads about the P0401 issue " EGR Flow Insufficient" and Cold Start Issue.
Tested the VMV (Vacuum Modulator Valve or Solenoid or Assembly) it would not hold a vacuum so I went to my local Toyota Dealer and bought the VMV for a 92 Camry Toyota Part #25870-62020 $105.48 (Parts Guy hooked me up and sold it for $80) Autozone had it for $78.99 shipped in 2 days. Other places sell them for $64 or $45 but you have to wait for it be shipped and not OEM.
Prior to this I took off the VMV and cleaned it out. Still had cold start issue but when warm it started right away. I reset the CEL but the CEL came back on after 10-15 miles.
Literally 5 mintues in the Dealer's parking lot (they were not too happy about that, but no one complained) and popped in the new VMV with a 10MM socket wrench, disconnected the battery. Bingo Trouble Code Gone, Started Right Up and running 100+ miles no issues.
Hope this helps someone with like issues.
Cheers
Jim
Old 08-09-08, 04:54 PM
  #67
rattler96
rattler96's Avatar
Default 96 ES Power Antenna
Hello, I recently purchased a 96 ES 300 and the power antenna is broken. I bought an aftermarket assembly with red, green and black wires. Could someone provide some insight into getting it installed?
Thanks so much!
Troup
Old 08-30-08, 11:55 PM
  #68
LW ES300
LW ES300's Avatar
Exclamation
Originally Posted by 3000
How to get headlights clean
people who have older cars have dirty headlights and they tried to wash it so many times but can never get it to be clear and shiny.
This product is garbage. They didn't reply to 2-3 email inquiries so I figured, "what the heck, this headlight restoration kit is only $14.95, I'll give it a shot." I'll say 1% cleaner, but all in all a worthless product.
just my $0.02
Old 09-04-08, 07:03 PM
  #69
BurgundyES
BurgundyES's Avatar
AC in my '96 ES300 kicks in but shuts off in few minutes, and in humid weather windshield and windows fog too much. What could be the problem?Does it need major AC work?
BurgundyES
Old 12-07-08, 05:53 PM
  #70
basketthis
basketthis's Avatar
adjust windows in es300:
https://www.clublexus.com/forums/es3...hone-pics.html
Old 12-15-08, 08:48 AM
  #71
RPToro
RPToro's Avatar
I'm having trouble accessing the write-up for removal of the radio from the first page.
Anyone have any suggestions on a good write-up w/ pics for this? I'm embarking on an FM-Modulator install in my brother-in-law's '98 ES300.
Also, I'm looking to put the connections in his arm-wrest center console. Anyone done this type of install and/or have feedback or suggestions?
Thanks!
Old 12-23-08, 10:34 AM
  #72
lexuslhs
lexuslhs's Avatar
Default lsr perfomance chip for 2005 es330
hi, just purchased an lsr performance chip, they claim to improve throttle response,gas mileage,shift quality,etc...the directions say to disconnect 2 wire iat or mat sensor and install this into connector..i dont have a iat or mat, just a air flow meter with a five wire connector..did you ever install one these? if so, do you know which wires need to be jumped, if at all possible? thank you..
JesseR209 (10-03-21)
Old 12-25-08, 11:10 PM
  #73
tribalrabb
tribalrabb's Avatar
Default 1994 ES300 Tranny problem
Hi, my ES300 is a 94 model. It runs fine but the other day the od light began flashing and it will go into OD then kick out. Also sometimes 3rd will "slip" then kick back in. it was doing fine until the other day. I have been reading about the self diagnostic check by jumping the plug. How is this done on the 94 es300 I found a plug next to the fuse box. The speedometer still reads out fine so I didnt know if the speed sensor would act like this.
Old 01-08-09, 11:19 AM
  #74
eyezack87
eyezack87's Avatar
The complete headlight HOW TO clean DIY + projector refinishing
Taken from SC's but same principle people. Just use something other than wax to clear up the housing thats all. A polish would work just fine
https://www.clublexus.com/forums/sc-...finishing.html
Old 03-21-09, 11:34 AM
  #75
70GS455
70GS455's Avatar
Just got done with removing the rear portion of the center console on my 03 ES300 so I could fix the front cupholder.
1. Remove the trim from around the gear shift ****. I used my fingers to pry up the rear section first, then pull up and to the rear of the car. Helps to have the trans in neutral. It has wires so don't drag it too far away.
2. You will see 2 phillips screws that join the front and rear sections of console. Remove those 2.
3. At the rear, remove the upper plastic piece with the air vents. With your fingers, pull straight back.
4. At the rear, remove the lower trim piece, pull straight back.
5. With the lower trim piece off, you will see 2 bolts attached to the floor, a few inches in (under the storage box). I used a swivel, socket, and extension. They are kinda hard to get to when putting back in.
6. The whole console assembly should lift straight up. But first, there are 2 places on the sides where the carpet hooks over 2 plastic tabs on the air ducts. They are about mid-way betwen front and back of the console. Find them with your finger tips and just slip them off. There is wiring attached so take care.
7. I had to replace the cupholder which was pretty easy, it's just 4 screws.
8. Installation is just the reverse.
Fdavis13 (09-01-22)
Quick Reply: ES330/300 DIY (do-it-yourself) & technical tips
