ES330/300 DIY (do-it-yourself) & technical tips
#91
It does not need to be a new remote, as long as it is the correct model for you car it should work. The programing procedure is used the get the reciever into a "learning mode" so that it will recognize the key fob transmitter as one that it should respond to.
#92
How to get headlights clean
people who have older cars have dirty headlights and they tried to wash it so many times but can never get it to be clear and shiny.
Plastex also works
#96
ES300714 -
The air filter should be basically behind the the dash on the bottom. If you reach near the gas pedal, you should be able to peel the carpeting up and see a slot where the air filter isnt, or you should be able to remove it. If you google around for air filter diagram it may be better able to show you
Fdavis13 (09-01-22)
#100
is there any write-ups to replace the motor mounts for the 3rd gen(97)? im getting a vibration at highway speeds, nothing at low speeds, front wheels balanced and alligned, no play in the wheels themselves, i should b looking at the motor mounts, yes?
#101
"How to Remove Stock Stereo Unit (PDF)" for the 97-01, no longer works. I found something similar here.
http://www.pro-fit-intl.com/Adobe/LX-51-92-p2.pdf
#102
Any info would be helpful.
#103
Sit in driver seat, driver door unlocked and open, all others closed and locked
manual open/close cycle 5 times each
close door
open door
...then nothing. No automatic cycling by receiver to confirm it's in program mode.
I even tried cycling with the power locks the second time as some have suggested... still no automatic cycling to allow programming of the fob.
Anyone have any ideas? Much appreciated.
#104
I have a 04 ES300, the door lock do not work with the key remote. Do I need to replace the complete actuator or is there just a motor or selenoid that can be replaced?
