Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
- Lexus IS GS: How to Change Brake Disc
Step by step instructions for do-it-yourself repairs
Brake pad and rotor change
bump on this. This morning I read this thread and started on replacing my rotors and pads off of my 97 es300. Big problem for me was removing the 17mm bolts. I sprayed some WD-40 and waited for 30mins with no luck. I tired putting my weight into it with no luck and im not a small kid (210pds).
Any info guys??
Any info guys??
When I replaced the brake shoes on the 98 i noticed a huge amount of play on the passenger side front wheel. Come to find out the control arm had some play in it. It was not coming from the rear of the control arm (towards the back of the car, which looks like a ball joint connection) but the middle of the control arm where it looks like about a 3 inch long bushing of some sort has been damaged. Do you have a step by step process to fix this? Do I need to replace the whole control arm? Looking on autozone website, they show a kit to buy whick includes the ball joint. I need some guidence on how to attack this problem...
Anyone have a list of tools I'd need to do this myself? Doesn't look like I need anything special but I hate getting into the middle of a job only to find out I don't have a tool I need.
Thanks.
Thanks.
"You should see (2) 10-24 pitch threaded holes on the inner bolt circle of the rotor. You will need to find a couple bolts that will fit in those holes (e.g. 12 mm size) and force the rotor to come out. That was the tricky part that I probably couldn't have figured out if my friend didn't help me"
Ok, this is the part which has me stumped. I can't for the life of me understand what you're talking about. Looks like I need to take the star-patterned bolt off in order to get the rotor off.
Help!
Help!
So I just changed the pads for now. Want to change the rotors soon, though, so I need to understand what, exactly, I need to do in order to remove the rotors. Not making sense to me.
Thanks.
Thanks.
You first need to obtain two bolts that will thread into the two holes in the rotor. Start both bolts and then tighten them, alternating from one to the other. As the bolts go in, they will push against the hub. This will force the rotor out and off.
Thanks.
