AC Problem
Old 08-11-04, 10:21 PM
Lexguy026
Lexguy026's Avatar
Default AC Problem
I just bought this lexus and i attempted to use the Ac and it only blew hot kinda semi cold air, is this because the system has to be recharged or somthing else?
Old 08-12-04, 06:36 AM
lexusk8
lexusk8's Avatar
A recharge is possible for the reason of A/C blowing hot air. Do you see the A/C light blinking when it is turned on? If so, it usually means there is something mechanically wrong with the A/C, particularly the compressor or the expansion valve (a common problem noted in the '92-'96 ES).
Old 08-13-04, 07:31 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Definitely sounds like a refrigerant problem if no other warning lights exist.
Old 08-15-04, 10:54 AM
Lexguy026
Lexguy026's Avatar
No Warninh Lights, but i just found out i cant recharge this system myself because its an R12 System, which sucks lol, i would have to bring it to a shop, unless u guys know another way?
Old 08-15-04, 11:29 AM
amf1932
amf1932's Avatar
You could buy recharge kits and R-12 from eBay.
Old 08-15-04, 09:51 PM
flipside909
Lexus Connoisseur
You can bring it into a qualified tech to recharge, have him retrofit or you can do a retrofit R12 subsitute yourself if you're mechanically inclined.
Old 08-16-04, 05:36 AM
Lexguy026
Lexguy026's Avatar
They do sell a kit at The Auoplace around the corner from me that allows me to retro fit my AC to conform to R-134a and it gives me a bunch of adapters n stuff, so ill try that
Old 08-16-04, 08:19 AM
Lexguy026
Lexguy026's Avatar
Hey i cant find the lower side pressure hose that i need to put the refridgerant in, do u guys know where u plug the hose in so that i can recharge the system, i think i found the High Side Hose Behind the Headlight but the instructions on the Reilling kit say i need to refill using the low side hose which i cant find????
Old 08-16-04, 08:09 PM
flipside909
Lexus Connoisseur
You plug in the hose on the fitting that looks like an oversized tire valve bung.
Old 08-25-08, 01:24 PM
lexis93
lexis93's Avatar
Hello. First post. Great forum
I've got a '93 ES 300 blowing warm air thru A/C
Was told by a mechanic to recharge it. I've gotten a can and a kit but having trouble finding the LOW valve. Could someone help in describing where to look or point it out on a picture? thanks
Old 08-26-08, 05:19 AM
GEORGE_JET
GEORGE_JET's Avatar
Low side fitting is near cylinder #1. Passenger side firewall. It took me a little while to find it on my car, but once you start looking near the firewall, it should be quite easy to spot.
Old 08-26-08, 12:58 PM
lexis93
lexis93's Avatar
Thanks George_Jet
I've actually seen that fitting before as I was searching for it. Isn't it a bit small though? the fitting seemed smaller than I've seen in my other car(mitsubishi), also LOW end.
Old 08-26-08, 03:01 PM
GEORGE_JET
GEORGE_JET's Avatar
Sorry, I can't comment on the size of the fitting. My car was converted to R134 before I purchased it, so it has the quick disconnect adapters installed. Good luck
Old 08-26-08, 04:28 PM
lexis93
lexis93's Avatar
Thanks, I'll check it out tonight.
Old 08-26-08, 09:56 PM
lexis93
lexis93's Avatar
Dammit, I've just noticed that my system is R12!
Doesn't look like it's a DIY anymore, looks like I may have to take it to the dealer. Does anyone know how much they would charge for a recharge?
Quick Reply: AC Problem
