Grill on 96 ES??
Old 08-20-04, 10:25 AM
lexusk8
lexusk8's Avatar
Originally posted by MoreMGD32
Does anyone know if the 97-01 lexus front grill will bolt up to 95 es?
It won't fit in a '95 ES. Only interchangeable within the '97-'01 ES models.
Old 08-20-04, 11:56 AM
BigRich
BigRich's Avatar
But I can put a 96 on a 93, right??
Old 08-20-04, 04:40 PM
AusLex300
AusLex300's Avatar
96-93?...Yes... They changed the design of the grill on the 97.. Not much from a 96 and down, will fit on a 97 and up. And vice versa!
Chris
Old 08-24-04, 11:13 PM
Ghetto-Pimp
Ghetto-Pimp's Avatar
i have 1995 Es 300
i want to get Chrome upper grill and bottom, if anyone has info on this
where can i get it
thanks, if i could get chrome grills, i can sell the stock grills because they are brand new
i just got them awhile ago.
Old 08-25-04, 12:06 AM
AusLex300
AusLex300's Avatar
Take it to a chroming place.. Thats what I am going to do.. But I would suggest that you paint the sides of the inner grill flat black to make the vents look like they run all the way across.. I dont like the look of a fully painted grill...
Old 08-25-04, 08:15 PM
jhenty
jhenty's Avatar
I've got my own homemade jdm grill in the works. I'll post pics soon. So far its coming out well.
Old 08-25-04, 08:20 PM
juan01
juan01's Avatar
cool, keep us updated
Old 09-18-04, 06:37 PM
skperformance
skperformance's Avatar
ES 300 grilles from 92-96 are available for $100 from teh dealer brand new and painted already to match. I think it is dirt cheap for a grille , i just wanted to be different and follow the design themeof the lower grille in the upper one.
Chroming the grille may not be as easy as you think as the metal it is made from is not steel but an alloy with a trade name of white metal for its colour. It is basically like a diecast toy car and has just as much strength . Softer than aluminum but cheaper and heavier as well.
I couldn;t even weld mine with a TIG( if you know what one is,it is a welding machine,tungsten inert gas) machine as it will not hold to it,only burn holes even with lower voltages.
Old 09-19-04, 07:31 AM
squarehat
squarehat's Avatar
Are the 95-96 grilles plastic or metal? (I can understand the 92-94, with the thinner slats, being metal) I was inspecting a small crack on the grille of my 96, and it felt like it was plastic (too light/soft to be metal, and didn't seem to have any metallic resonance when tapped).
Old 09-19-04, 06:26 PM
skperformance
It is also metal just aslightly different design but like i mentioned it is a diecast so it does not feel or act lik a regualr plain steel but more of an alloy.
Old 06-10-08, 05:18 PM
Trexus
Trexus's Avatar
Today I ordered a grill for my 1996 ES 300 for $110 brand new from Carson Toyota. That's not to bad for an OEM part. My old grill got old and fell off, not sure where but most likely on the freeway
Old 06-10-08, 08:57 PM
tuan92129
tuan92129's Avatar
I'm looking to buy a used 92-94 es grille, if anyone has one
(JDM grille here i go!)
DunWkg
07-22-21 07:28 PM
HYPERBOY
07-08-07 12:34 PM
GSXOTIC
10-11-04 01:50 AM
MCV20
13
04-29-03 02:43 PM
Sabs
05-31-02 08:56 PM
Quick Reply: Grill on 96 ES??
