Air conditioning
My 96 ES 300 's A/C doesn't seem right....
It can blow cool air but not cold air. Even I turn to MAx Cold....It cannot cool the interior...
Help?
Help?
WHat u guys mean is the exapnsion valves?
Where is it?
Is there a leakage on the parts?
I saw some of the R134 A ahave seal function. Is that help?
Where is it?
The expansion valve is located inside the car under the dash adjacent to the evaporator.
Problems with this valve are very common on first generation ES 300's. As I understand it, the valve sticks. There is apparently no fix other than changing out the valve.
I had mine repaired by a local auto air conditioning facility. The cost was about $425.00. This included replacing the receiver-drier, evacuating and recharging the refrigerant, and leak testing. The local Lexus dealer wanted $700.00 to do the job.
This is not a do-it-yourself job. Special tools and AC expertise are needed.
i have a 1995 lexus es 300
and im having the same problem
my Ac works for few minz then its blowing hot air,
what you guyz think the problem could be on mine, it works fine when i just turn it on after 2 or 3 minz
its blowing HOT AIR
i had it chekced and the shop guy said everything lookz good and working the only problem is the CLIMATE CONTROL MODULE which makes the heater go off,
anyone has this problem please help
its too hot in cali i need the Ac
thanks
its blowing HOT AIR
thanks
my 95 es would blow ice cold for about an hour then start getting warmer until no cool air. Also started with warm air only from driver's vent
It was also the EXPANSION VALVE, mechanic could not diagnose until I got the car to do it and brought it to his shop and left it running out front. Within the first hour when it was working,mechanic could not diagnose.
expansion valve replacement fixed it perfectly. Mine cost around $250 for repair(local mechanic)
There is nothing to be gained by adding refrigerant unless the system has a low charge. Have you checked for bubbles in the sight glass?
The expansion valve problem has nothing to do with the refrigerant level. I had the pressures checked several times while my car was having AC problems, and the refrigerant level was never low.
yah, the prssure test thing is not just to check the amount of refrigerant-they can also tell if the expansion valve is working right by the pressure changes.
Just go to a reputable ac/radiator shop. I cant see them charging more than $50 or so to check it out
Help?
Help?
If the belt is OK.....then make sure the compressor clutch is engaging and actually spinning the compresor. If that is OK......THEN start to look at the R34 level or expansion valve.
