where can I get a wood and leather steering wheel?
Where can I get a wood and leather steering wheel for my 97. I want the one the 2000 and 2001 have. Also, want the gear shifter.
You can order that through any Lexus parts counter...the wheel is a direct fit since it mounts the same from 97 to 01. You can try www.l-tunedparts.com or better yet call them directly. Ask for Bobby and they should be able to quote you a price. As for the shifter...are you talking about the ****? That's just a twist on/off operation. You can order that same part from them as well. Or if you want, e-bay or even the local junk yard.
Originally posted by sunman
what about the overdrive button on the side of the shifter?
The OEM wood wheel can go upwards $300 and up for a used one from a junk yard. OEM will cost you an arm and a leg from parts counter.
You may wanna check this thread out:
https://www.clublexus.com/forums/sho...threadid=67627
Originally posted by branshew
you could also try American Stitches - they can redo your existing wheel for @ $500.
psls400
29
09-27-04 01:26 PM
Gaymond Le
01-19-04 07:22 PM
