Rear Door Panel Removal
I've got a 1995 ES300 That someone was kind enough to bust out my rear window on last night.
Kind of in a Jam to get it fixed.
I took out plastic plugs on leading edges, the screw in the bottom of the door grab (underneath the plastic cover).
Something is still holding it near the latch. How do I get the screw out ??
Am I missing anything else?
Lexucanafer
Yes, the door handle bezel is the trickiest part to deal with. It has a molded plastic "hook" at the back, on the edge furthest from the door handle itself. This hook goes in behind the door panel. So, when you gently pry the bezel out, do so from the edge closest to the door handle and lock mechanism, and then try to slide the bezel sideways over the door handle.
