View Poll Results: What problems you have run into in your ES?
Burnt out instrument needles or lights
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
356
45.52%
Valve cover gaskets or rear main seal (causing oil leaks)
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
234
29.92%
Failed heated seats
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
90
11.51%
Peeling of B-pillar (between front & rear windows)
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
149
19.05%
A/C defective
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
91
11.64%
Yellow or hazed headlights or foglights
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
276
35.29%
Transmission hesitation, or lag of acceleration
272
34.78%
Antenna
214
27.37%
Window regulator
146
18.67%
Motor mounts
125
15.98%
Multiple Choice Poll. Voters: 782. You may not vote on this poll
Problems with your ES?
#47
Originally Posted by OceanView
I wanted to add, that my squeeky steering wheel still makes people laugh when they here it for the first time.
The other day a friend of mine who was taking a ride with me noticed that the volume goes up and down slightly when listening to the radio. This also happens when listening to a c.d. anyone else ever have this problem? If so what is the solution?
#48
Originally Posted by superpats
What the hell is up with this? I thought it only did this in cold weather but I guess I was wrong (93 the other day when this happened to me) Anyone have a fix for this?
https://www.clublexus.com/forums/sho...2&postcount=18
#50
Hey Doug, Is the rubber boot by the floor where teh pedals are? Also do you know what they used for lube?
#51
Originally Posted by lexusk8
I'm not exactly sure where the rubber boot is, but if you go on http://www.newlexusparts.com and navigate to the steering system of the ES, I'm sure you'll be able to find its specific location.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#52
I just purchased a 99 ES 300 black/black coach ed. with 88k miles on it, one previous owner who did perform both the 30 and 60k services on it (I am unsure about other service b/c I bought it from a dealership). It looks like it is in very good condition but this thread is making me nervous- how common are these problems? i see the reply's and it seems as if everyone has had a problem at some point, should I have gotten a different vehicle?
#53
Originally Posted by Dandybug
I just purchased a 99 ES 300 black/black coach ed. with 88k miles on it, one previous owner who did perform both the 30 and 60k services on it (I am unsure about other service b/c I bought it from a dealership). It looks like it is in very good condition but this thread is making me nervous- how common are these problems? i see the reply's and it seems as if everyone has had a problem at some point, should I have gotten a different vehicle? ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
BTW, welcome to CL Dandybug!
#54
Thank you!
I am excited about getting the car on Friday (it was brought to Seattle by truck from California and needs a new bumper due to an accident getting on the truck)... so in the meantime I have been trying to read up on it...I had a 5spd maxima that was totalled and initially was looking for a maxima but was having little luck then I found this car and it was meant to be!
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#55
Thank you!
I am excited about getting the car on Friday (it was brought to Seattle by truck from California and needs a new bumper due to an accident getting on the truck)... so in the meantime I have been trying to read up on it...I had a 5spd maxima that was totalled and initially was looking for a maxima but was having little luck then I found this car and it was meant to be!![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Also, my tranny is shifting hard... it takes long to go into gear when I first start it up in the morning. The tranny fluid was changed last December 04. Not sure what it is yet, the dealer is going to check on that.
Hope all goes well.
#56
I've had two ES cars 1997 and 2004 and I have not had any major problems at all. On my recent one a rear window shade failed but they fixed it right away with terrific service and a smile.
#59
awesome- i like the "no problem" cars- hopefully that is what i am getting!
- Currently has 115,400 miles, and my daily driver (to school, 7 miles each way). I fill with 87 Octane fuel (I see no difference than filling up with the premium kind, but let's not get into that issue). I help maintain the fuel tank and injectors by giving the car some Techron fuel injector cleaner 2 times a year. I keep my car clean and detailed once every 2 weeks, and I do it myself as I have all the necessary supplies (from Meguiar's, Eagle One, P21S, etc.) I also do my own oil changes (with 10W-30 Mobil One full synthetic). I follow the recommended maintenance schedule from my owner's manual (soon I'll be due for a coolant and differential fluid change). My ES literally has no problems whatsoever; it's so beyond excellent condition, even my neighbors and friends can't believe it's just a 2001 vehicle
