View Poll Results: What problems you have run into in your ES?
Burnt out instrument needles or lights
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
356
45.52%
Valve cover gaskets or rear main seal (causing oil leaks)
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
234
29.92%
Failed heated seats
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
90
11.51%
Peeling of B-pillar (between front & rear windows)
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
149
19.05%
A/C defective
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
91
11.64%
Yellow or hazed headlights or foglights
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
276
35.29%
Transmission hesitation, or lag of acceleration
272
34.78%
Antenna
214
27.37%
Window regulator
146
18.67%
Motor mounts
125
15.98%
Multiple Choice Poll. Voters: 782. You may not vote on this poll
Problems with your ES?
#106
Just found this Lexus forum, my first one in addition to 2 BMW-related forums. First post!
Just got the '96 ES back from the dealer last week after asking them to do an inspection of the car. Getting the grocery list of issues (and stratospheric estimates), I came here and was surprised (kind of) to see so many of the same problems plaguing other ES owners. So lets see....
*cracked engine mounts need to be replaced......looks like I'm not alone
*backlighting issues.........not alone (and yes, I did bang plenty and hard on the dash as I read in the sticky) At least all the LED needles are perfect.
*antenna.......was fixed a few years ago.
*valve cover gaskets.............I see that's also common here.
*window regulator..........officially not a problem, but I know the front passenger one is gonna be the first to go south.
*transmission hesitation..........yea around 10mph it shudders a bit and seems confused, but all Toyotas seem to have this issue. Solenoid was replaced earlier this year when it really did go bad and prompted a check engine light and nothin but 3rd gear.
There's a couple more which I'll search or put into new threads.
#107
i just got a 94 es300 today. one headlight lost its seal and is dirty and yellowish on the inside and one of the needles flickers after being on for a few minutes.
Anyone know how easy or ehard it is to remove the headlights and tail lights to clean them is??
and anyone know any easier way to fix the the flickering needle without buying a new instrument cluster??
#108
Mine's a '94 ES300; I've had it for 10 years and it has 193K+ miles. I love this car! It's had problems, but not all at once. They include:
Left rear window regulator went out (didn't bother to fix).
Side and front motor mounts replaced this year.
Can't keep the headlight lenses clear.
Instrument needles have been flickering for about 3 years.
Rear main oil seal leaking.
Antenna gave up the ghost long ago.
Motor for moonroof closed one last time (thankfully!) before one of the hurricanes hit 2 years ago.
Cracks in leather front seats and by seam of back seat.
O2 sensor causes CE light to stay on for past 4 years.
When you write it all down, it seems like a lot -- but I've put 170K on this car in 10 years and still wouldn't hesitate to do a long road trip.
#109
My B-pillar had also peeled in my '01 ES, so what I did is replace the darned thing. Costed me about $60 from the Lexus parts counter; the part already comes as clearcoated. It is far better than the $100 estimate to have the body shop repair and re-apply clearcoat to the part. Just something for you guys to consider ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
#110
i notice the windows in the front move up slower the the rear........
the tranny kicks sometimes when i slow down to make a turn and then i hit the gas and thats when it kinda feels like it goes no where and kicks, the rpm's sorta drop......
thats all for now
hopefully it'll be good to me
thats all for now
#111
Sounds like it might be an MAF sensor? I just had one replaced on my car not too long ago. Take it over to an Autozone and they should be able to scan the ECU for free.
#112
Hi..I am having a problem that the dealer is even having a hard time determining the cause of. I have an ES300 automatic and since the weather has turned cold it doesn't want to start. The engine is turning over and it trys to start but won't fire. We can hook up a battery charger and the car will start. The battery has been replaced and the alternator is good. Cables are fine too. Warm days the car starts just fine and runs good. Dealer did mention that it could be the "air flow sensor" but since they had it for 2 weeks and it started every day they couldn't determine the cause. Has anyone else run into this issue or have any suggestions? Thanks
#113
I got a P0446 evap malfunction,I have to replace the charcoal canister because it leaks fuel!!Good thing I'm getting a discount on it!!
Damn California spec cars,Federal cars don't really have this problem!
#114
97 es 300 w 155K+................engine light on, trac comes off and on. ran diag test and came up with code P 0773 shift soleniod E 5 circuit.
question is, should this matter be addressed ASAP? and what costs are we looking at here?
BTW, first time posting on site, been monitoring for a few months now and have thoroughlly enjoyed the professionalism and assiatance that has been exibited on this site.
( no mods other than clear corners as of yet)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#115
You should get that shift solinoid fixed or replaced "asap" because your transmission may start shifting harsh or not shift in to some gears at all,if doesn't already do so,
thus will also affect your fuel economy if it does not shift into overdrive(aka 4th gear on a 97 ES300)!!
#116
i manage an auto body repair facility that specializes in lexus vehicles (johnson lexus to be exact) and before i take it up there, i may try and have a friend/mechanic solve this issue. just dont wanna get taken for a ride.
#117
well i been on the forums awhile but when i went into my old account it wouldnt let me post but anyway...i got the typical problems of a lexus has......burnt out needles.....antenna broke(maKING that annoying sound...braggggehh.....and my ejr valve is bad causing my check engine light to come on.....
#118
Hi I am Sophia, I own a 2000 ES 3000 Platinum Series. I had the alternator replaced in Nov 06, and right after then my trac off/on light comes on along with ABS light. It doesn't stay on all the time. I had my mechanic check it out and they couldn't find any reason for it to be on. They suggested I take it to the Toyota dealership. Also today I hear my brakes squeak, the front brakes have been replaced within the past year, but not the back. Also about two weeks ago, my car felt like it was skipping. Then the check engine light came on and it started making a horrible loud noise. I parked it and had it towed to my mechanic and he said that who ever tuned up the car, broke or cracked a spark plug. They replaced the plug and ignition coil and it has run fine ever since. Total price $291.
#119
thats all for now
thats all for now
