looking to buy an ES , help
rss, you gotta give us more criteria info on what you want for your ES purchase. Then we may be better able to help you out ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Also, use the search engine if you're unfamiliar with certain ES features.
Speaks French in Russian
Originally posted by rss
I don't know !
It's between the 1995 GS300 and the 1995-96 ES300... I don't know which one to choose?!
I don't know !
I don't know !
I don't know !
The ES has fwd which will be better in winters.
Originally posted by Faraaz23
If you wanna mod it, definetely go GS... there's a good number of body kits, suspension parts, engine mods (for the famous 2JZ-GE motor... same block as used in the Supra), and can accomodate larger wheels than an ES. The GS has more power and is RWD which also helps from a performance point of view.
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
thanks for the info.
Where I live, we get long cold winters.
So I'm leaning towards the ES for the FWD part... What power do those 95/96 ES's put out?
![Embarrassment](https://www.clublexus.com/forums/images/smilies/redface.gif)
