Open the trunk. Check behind the fuel door inside the trunk. Pull the handle dangling from a cable specific to this issue, maybe behind the Furst Aid kit. Close trunk. Fuel.
Drive away.
That's not the issue in this thread, you should read the original post carefully.
I was thinking maybe if that spring fails, you could use a plastic pry tool to put pressure on the fuel door as you pull the cable. That way once the fuel door is unlocked, you can swing it out instead of relying on the spring mechanism. Should definitely work in a pinch until you can get that fixed.
