97 fluid leaking, power steering?
I have a 97 es 300, 75,000 miles. There is a fluid leak on the passengers side near the right front tire. Fluid is olive oil color, possibly indicating power steering fluid leak, leak appears to be coming from what I believe to be the power steering pump near the pulley, can't actually see the leak, only where it's dripping off the frame. Checked all fluids, nothing is low.....yet. Are PS leaks a problem? How should I proceed to verify the problem and correct it? New pump? Seal Kit? How hard are we talking?
Thanks,
Mike
Thanks,
Mike
Lexus Connoisseur
Thanks,
Mike
Thanks,
Mike
Dysfunctional Veteran
Originally posted by flipside909
Power steering fluid should be a red fluid since it uses Dexron III ATF. If you have an olive oil colored fluid, it's probably not your power steering unless the person who last changed your power steering fluid put the wrong stuff in.
the fluid in the reservoir is an olive oil color, and I have read before that the factory fill is olive oil color, can't pic up a smell.
Lexus Connoisseur
Hmmm i've seen both red Dexron ATF and the olive colored p/s fluid used for both applications.
Lexus Connoisseur
As for your fluid, you may want to see where the fluid is leaking from...either your pump that's leaking or possibly the rack. Either way, both are expensive parts to repair/replace unfortunately.
attzor
Performance & Maintenance
10-11-12 09:56 AM
