Will 1998 ES300 rims fit 1994 ES300???
RX 300 & 350Z Guru
Sorry about the slow ES forumn. The RX forumn was that way at first. There are SO many ES's out there just not enough enthusiasts - sad to since the car looks so great. Not sure about the fitment of the 15's but did you consider the 16's that they use on the 2001's - same body style as the 98 ES so if the 15's will fit the 16's should to and they look awesome!
Below are the pics are the 15's and then the 16's. I will also put a picture of the Coach Edition Wheels just so you'll have all the choices out in front of you. Hope this helps you some. If you go to http://www.800wheels.com you will find some good pictures and information.
I scored a set of the 1998 rims, flawless complete with valve stems and locking lugnuts for $300, very nice deal. They are the 15". I have also seen the alloy ones on the bottom right 16" for $600, almost bought those. As to the 2001 ES rims, I think they look horrible, too bad.
I called the dealer and they said the 98's would fit.
Aceshigh
05-04-12 02:16 PM
