01 tailight problem
01 tailight problem
I just installed the 01 tailights and all of them worked fine except the innermount on passenger side (with trunk lock). I will put in new bulbs tom, but can there be any other problem(something I should look for)?
The lights dont work on the innermount taillight with the trunk popper(es 300 badge taillight).. On the stock one , I pretty much ripped it ou cause I didn't notice the one screw that was hidden in there. Also the 2 screws to the trunk popper broke, but that shouldn't matter. I will try to fabricate something, probably just use a powerdrill and make 2 new screws to lock in the trunk lock. I can still pop the trunk with the button on the inside of the car and from the remote(which I always use anyway). I'm going to get 2 new bulbs right now and if that doesn't work can there be anything else wrong(something I should look for)? All 3 other tailllights work and look great though.
Since you said you ripped the old inner tailight out from the passenger side, there's a possibility that you may have disconnected or broken off a couple wiring harnesses to the bulbs. Check all wiring and make sure they're OK.
Do you have any before and after pics of the ES tailights to share with us? I like to see how those new tailights look with your factory grey ES.
MIGS
SC- 1st Gen (1992-2000)
20
03-31-11 10:13 PM
