ES or RX for snow ?
ES or RX for snow ?
Hello all,
I plan on buying either an RX or ES for the snow in NJ as the LS doesnt seem to go anywhere in snow !
i know that RX is AWD, but I have driven FWD and they are as good in snow.
my question is. if I were to get a 98 plus model ,with same miles, year and condition, which model should I opt for. RX or ES ?
i appreciate the input.
I don't plan on offroading and normal road driving doesnt call for higher ground clearance.
would that be the only plus for an rx ?
the downside i see to the rx is the instability factor at highway speeds in comparison with the ES.
Originally Posted by Lexs400
Hello all,
rx isnt AWD, it has 4WD optional
i say go with the rx
Definately an RX cause of the 4wd and ground clearance. The RX had no problems with traction and getting stuck in the snow. When the snow storm hit last weekend, i got stuck in the ES becuase of the low clearance and it is a lot easier to slide around in corners.
RX for the above mentioned reasons, however if the roads you drive happen to be plowed etc. the ES wouldnt be a terrible choice. If you choose the ES drive with a little thing I call common sense...-cough- no driving on unplowed roads -cough-
Compaq
RX - 1st Gen (1999-2003)
16
02-20-03 01:34 PM
