these sway bars fit???
Originally Posted by flipside909
You don't have to cut the hood supports. that's bs.
https://www.clublexus.com/forums/es-1st-to-4th-gen-1990-2006/89031-trd-strut-bar-install-for-97-es300.html
I have just replaced my OEM struts/mounts with KYB strut mounts. I have ordered Solara strut bar and TRD RSB.
I want to get urethane bushings for the RSB and FSB and have looked at whiteline and energy suspension, but am confused. I am not sure if the whiteline bushings will fit the stock ES300 FSB or the solara TRD RSB? Also, when looking at energysuspension, they show a RSB bush, but I am not clear if it will fit the TRD RSB as well, they show an 18 and 19mm universal option for the FSB, but I don't know which one mine is (I don't have access to a caliper).
Can anyone tell me what parts I need to order and where is the best place to buy them?
Also, should I replace the sway bar links as well? Is there urethane options or do I have to get OEM?
I have a 1997 ES300.
Thanks much
Dan
Thanks much
Dan
Yeah you don't need a front sway bar for your ES. Just stick with something like the TRD Rear Sway for the Solara. It will fit your vehicle and it's adjustable, race and street setting. If you have the factory AVS system, getting coilovers will negate that system. You are better off doing a mild spring drop if possible i.e. Eibach Pro-Kit. If you want a lower than 1" drop, get the MCV20 Solara version since it does provide a 1.6" drop. Good Luck.
Lexus Connoisseur
Originally Posted by lexbox
Im interested in a Rear Sway bar but I have a 96? What, if any, Solara options are available to me?
http://www.whiteline.com.au/
None unfortunately from the Solara. But have no fear, the MCV10 Camry V6 has a Whiteline sway bar available for you!
*added*
Nevermind found it. BTR36
kyoso23
Suspension and Brakes
14
02-01-09 01:32 PM
