1997 ES300 Suspension Repair Costs?
Hello everyone,
Just joined the board, but used it when researching my car purchase. I recently purchased a 1997 ES300. From this board I was aware of suspension issues and sure enough mine was found to need suspension work during the pre-purchase inspection.
Knowing the work was needed, I still bought the car which had 74K miles and was in cherry condition in all other areas for $10,300
I have decided to purchase the parts myself and take it to an indy for installation. This is what I have found. What do you think of the price, reasonable?
Replace front struts and mounts (243 parts from tirerack) + (240 labor)
Replace rear struts and mounts (285 parts from tirerack) + (240 labor)
Note: purchased strut insulators and bumpers ($82 from irontoad)
Replace front lower control arms (160 parts off ebay) + (170 labor)
4 wheel alignment (65)
Total Parts = $770
Total Labor = $715
TOTAL JOB = $1485
I plan to get the job done the end of next week so your thoughts in advance will be greatly appreciated.
Thanks, Dan
Total Parts = $770
Total Labor = $715
TOTAL JOB = $1485
Thanks, Dan
I took my car in the shop today and had them replace the front and rear struts and mounts. Also had the front lower control arms replaced. They did 4 wheel alignment. Great improvement in overall handling and the noise is rattling noises are now gone. I bought the parts from 3 different places and after many quotes went with a local indy for the labor. Price ended up at just over $1100 (475 parts and 625 labor). I researched and worked to get the right parts and the best price. Others may have seen bettter deals, but I am happy with my end product. Went with KYB struts/mounts, stock used springs, OEM bumpers and insulators and aftermarket control arms w/ball joints.
struts/mounts - tirerack.com
control arms - worldsuspension.com
bumpers/insulators - irontoad.com
Next, I am going to add TRD rear sway bar, Solara stock strut bar and new bushings for the FSB. I expect this work to be $$350. Then I will be done with the suspension work.
bars from toyotaparts4u.com
bushings from ?? made by energysuspension.com
Dan
Dan
Is it necessary to remove the gasoline tank in order to replace the rear suspension arms on a ES300 year 2000.
Underneath the middle of the car (between the gas tank and the trunk) the 2 long bolts that secure the 4 suspension arms in place cannot be removed - the gas tank is in the way.
Thanks
Thanks
i had problem since long time i checked with walmart mechanic they took my car and said thell do wheel balancing after that they said they cant and dont charge me anything, and said its problem with front passenger (suspension)
then they say they cant repair ive to go to some professional suspesion repair or replace
iam really confused from were to start with
i really donno which part is that suspension or any other
My car is so good runs well no problems except (steering shake) since a year (2000) es 300
any advice help pls.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Well, if you have a floor jack at home. Raise the front end. place jack stands for safety.
Grab the wheel then push and pull.
It could be control arm/s, tie rod ends or steering rack bushing.
We won't know until you see it for yourself.
Does the 1997 Lexus ES300 strut have the Adaptive Variable Suspension?
Should I purchase the entire strut assembly or just the strut and what brand is better?
Personal suggestion: go with KYB struts and replace strut mounts with factory Lexus units. Also pick up a set of two front strut bearings. The rest can be reused. Sometimes the rubber insulators that the springs sit on will parish over time, so you may need those too.
If your car appears to be sagging/sitting lower in the rear, that will be fixed by new struts. No need for new springs.
ckwasi92
05-14-14 05:42 AM
reelman4
05-25-11 04:31 PM
3rdelement
05-04-07 09:16 PM
