rubbing sound from steering column
i have a slight "rubbing" sound/feel when i turn my steering wheel. anyone know if this is a WD-40 fix or something more?
i've got a '98 ES with 109k
i ahve it too....i dunno wut it is, i never really checked either...i juss play my music louder than it is so it doesnt irritate me more than it being there already does
manlee, does the noise occur when it is cold outside? If so, then don't worry about it. I believe it's attributed to the density of the P/S fluid. It's usually thick when the outside temperature is pretty cold, hence causing the "whining" noise when turning your steering wheel.
hey,
same thing happened to me last night .. the weather was cold ...low 20s i think.
really embarrasing especially there were guests in the car. im going to ask the tech to check it the
next time i go in for service.
tim
tim
I used to get it done for free when the car was still under warranty. The last time I did it, the warranty was over and it cost $52.25 for Labor only. Lube was free.
This is what was on my receipt.
DIA Found Dry Lubricant Operating as Designed
Steering Shaft Boot Lubricated
I have the same thing going on. It doesn't happen in the summer time though. It is a bit embarrasing, but I just go heavy on the bass when parrallel parking
Thanks!
I might just try to DIY when the weather warms up. Mine is rather annoying since I have to make 20+ turns to get to my parking space in the garage.
Thanks for everyone's help.
