iPod for my '94 ES300
Well I just bought my first Lexus after having a '92 4Runner for many years.
With the 4Runner I bought a PIE adapter that ran from the back of the head unit (pioneer) and I was able to plug in an rca cable so that I could listen to my iPod through the stereo speakers.
How can I do that, if possible with my ES300? Is there an AUX out on the facotry Head Unit?
Thanks in advance.
Jeremy
Thanks in advance.
Jeremy
Originally Posted by steviej
what about something like the iTrip seen here
ok so im running a 20gb nomad jukebox 3 in my es. It runs really great with the assistance of a monster cable radio fm adapter. Especially since i installed a clean cig power plug into the armrest. now its all hidden and with the addition of a remote for the nomad its all seemless. Sometime take a look in the arm rest(center console) when you pull up the felt mat in the bottom you notice a nice little plastic punch out.
anyways yes the quality drops. But i am doing the same thing. Replacing my alpine deck with another that has ipod controls.
I use a cassette adapter to run my iPod in my SC. It is an excellent setup! Sounds better than a regular cassette because of the higher quality source. This is a better option than an FM transmitter if you have a tape deck in your car.
best option for ipod in ES or anycar in my opinion is the Alpine desk with ipod control/ainet interface. I just sold my nomad 20gb and im buying a 60gb ipod. The just $99 for the ipod controller for my new deck. I'll post pics once the customized guage cluster comes back.
After using a FM Modulator, I quickly want another option--sound quality is the dominating factor. I was reading the Crutchfield Car Stereo Installation Guide and there was a mention about adapters which connect directly to the control cables that would attach to the CD Changer in the trunk (without having to install an after market stereo). My CD changer [in the 2ES does NOT work--"Error"]. So, chances are I'll have to purchase a new stereo for install. But will still search in the meantime... [Nope, don't need a system that'll be heard 10 blocks away, but AUDIO QUALITY has always been a staple].
There is an extended thread in the Audio section of the Special Interest part of the forum which covers the addition of an auxiliary input to the sound system wiring. Several posters on this thread have indicated that their changers were not working, but they were still able to install a new working input. The installation described in this thread involves installing a relay into the wiring to enable one to switch between CD input and other inputs (ipod, satellite radio, etc.). Since your changer is inoperative, you probably would not need such a relay. You could just cut the four lines carrying the sound signal from the CD (R+, R-, L+, and L-) and connect these to your new auxiliary input. Note however that there still must be connection between the radio and the CD changer, so one should make certain that they leave the other connections (those not mentioned above) in place.
This thread is extensive, but it covers in considerable detail numerous installations in various Lexus models. I did this myself in the 93 LS I previously owned, and it worked perfectly.
Thank you very much for the information CU. I'll do a search for the thread, especially since you've mentioned it's "extensive". Looking forward to giving it a try, as I grow tired of the "blackout" spots--places/zones local broadcast interfere with the modulator's own transmission. [BUF: Best User Frequency is 88.1 MHz]. Again, thank you--let's see what where this goes.
