Just got an ES300 but I need help with modifications?
I just bought a 1992 ES300 and I want to do some OEM modifications to update the car to a newer year ES300. In the past thread I read that I could update my fog lights to the 95-96 version, is this a direct bolt on or would I need to change the plastic grille in order to fit the square fog lights. My ES also has a messed up front bumper due to curb damage what newer year ES would I be able change the front bumper to...Tail lights are also damage, it leaks water on both side...is there a newer year ES I can change that to...Any help would be great? Thank you
To answer your questions:
Yes, you would need to replace the plastic casing that holds the '95-'96 square fog lights as well.
All front bumpers are the same in the '92-'96 ES, so your only option (other than taking it to the body shop for repairs) is to find a front bumper from another '92-'96 ES.
Finally, the tailights in the '95-'96 ES are different than yours, in that there is an amber turn signal strip that runs across the length of the tailight. However, I remember reading that the physical dimensions between the tails of the '92-'94 and '95-'96 are also different, so replacing your tails with the later model ones is not feasible.
