Turn Signal Woes
I have just taken delivery of my '94 ES 300 (47kmiles) and when I use either turn signal it flashes very fast. Bulbs are blinking so I don't think that is the prob. Hazards flash slowly as normal. Any ideas?
JD
JD
There are 2 flashers, 1 for the turn signals, and 1 for the hazard lights. So I would make sure that all the bulbs are working properly, and if they are, then I would check the turn signal flasher.
I bet the bulb(s) or sockets are at fault though. The bulb sockets sometimes build up oxidation which causes erratic operation and they may need cleaning.
Where is the turn signal flasher located?
JD
JD
JD
JD
JD
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
JD
JD
