Replace high mounted rear brake light on 98 ES300
The high mounted rear brake light burned out. How do you disassemble to replace bulb and what is bulb # Thanks Bargelin
Very easy to do, just pry up the subwoofer/light cover from the rear deck (it is attached with 2 "clips" in the front of the cover), unplug the wire going to the light, and pull the cover towards you. The light just rotates out and you can replace with a 7440 bulb. Pretty easy, huh?
i couldnt have said it better
