Car Stalls at Start - Help!
Hi,
I recently purchased a 1997 ES300. For some reason when I start the car without giving it gas for a couple seconds, the rpms drop and the car stalls. If I give it gas when I first start it then I have no problems.
Can anyone help me figure out how to resolve this situation?
Thanks,
Shalom
Thanks,
Shalom
Hi,
Thanks for your reply,
I've added some fuel injector cleaner. Not quite sure how to clean the intake on this car, though... Can you offer any links to this... Would throttle value spray be a good idea?
Thanks,
Shalom
Thanks,
Shalom
Dysfunctional Veteran
get some throttle body/air intake cleaner from autozone or wall mart. just about any brand wil do.
remove the hoise that connects the airbox to the intake manfild. pull the throttle cable until you see the inside fo the buttervly valve (the only thing that moves inthe throttle body when you pull that valve. thats what you gota spray. but make sure the car is running when you spray it, if its not, you could flood it.
tats the easy one and it will get you by for awhile.
the harder version involves taking of the Upper intake mainfold itself and cleaning the entire thing. that i cant help you with. i can do it on mine, but mine is an entirely different motor.
Im gonna do mine the easy way, probably tomorrow. if you want, i can take a few pix.
hi,
thanks again! if you could take some pics i would really appreciate it. i have done numerous repairs on my sunfire but i dont want to mess up the lexus![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
shalom
shalom
speedmike
Performance & Maintenance
12-11-12 06:43 PM
