Where to run Amp Power Wire?
What spot in the firewall are you guys running your power wires through? I can't seem to find any holes....(not as easy as Hondas!) Should I drill one? TIA
Before I upgraded to the 1/0 guage I had to tap my own hole which is kinda hard considering the angle(I always run on battery side). The 1/0 guage is so big I had to run it under the car and its strapped to the fuel lines coming in the trunk by the stock cd changer location. You can try to find a rubber grommet but you gotta dig deep if its even there.
P Rock
05-04-07 05:42 PM
Stub333
13
05-09-05 09:54 PM
