1st Gen armrest inserts
Old 04-10-05, 03:40 PM
doodles714
doodles714's Avatar
Default 1st Gen armrest inserts
Does anyone know if you have to remove the door panels to replace the plastic armrest switch housings?
Both of mine cracked over the winter.
95 ES
Thanks!
Old 04-11-05, 06:48 AM
ssultan
ssultan's Avatar
No. Definitely not. They pop up, held in place by clips. Just wrap some tape around a thin flat head driver and pry it up gently starting from the front.
Old 04-11-05, 06:49 AM
ssultan
ssultan's Avatar
This ofcourse applies to prying up the 'wooden' insert as a whole, not the individual switch levers.
Old 04-11-05, 10:19 AM
doodles714
doodles714's Avatar
This is a first generation : 92-96
Old 04-11-05, 11:18 AM
ssultan
ssultan's Avatar
Whoops. Now you've got me
Old 04-11-05, 03:45 PM
Bluesman
Bluesman's Avatar
I plan on replacing mine as well. Does anyone know the answer to this one ?
Old 04-12-05, 12:10 PM
Lexbox
Lexbox's Avatar
Yes you do. There are 2 phillips head screws at each end of the insert from inside the panel. Then of course you have the screw you can find by popping up the plastic piece in the hole. If you are wondering why, the screw that you probably have already found helps keep the entire panel held onto the door itself. While the other two hold the insert to the door panel.
Old 04-12-05, 02:20 PM
doodles714
doodles714's Avatar
Thanks - I had a feeling that was the case.
Old 04-20-05, 04:58 PM
Bluesman
Bluesman's Avatar
I'd like to try and replace these myself if it is not too difficult. Hence, my next question is how do I take the door apart to get to these screws ?
sightdev
RX - 3rd Gen (2010-2015)
02-02-11 05:26 PM
joeker
09-21-08 10:56 PM
Magia120
11-07-04 12:02 PM
tmorales
Maintenance
08-12-03 10:11 AM
chrislee8
04-10-01 07:44 AM
Quick Reply: 1st Gen armrest inserts
