Need Help On 2001 Trunk Light!
I got my new trunk light on ebay but my light from my 97 doesn't fit inside my new 2001 trunk light so how can I get the wires to fit? Can I buy some more
SOMEONE HELP MEEEEEEEEEEE!!!!!!!!
Originally Posted by johnnyt
there are direct fit if the seller gives you the bulb harness. It should have came with.
You might be sol, first contact ebay seller and see if he has it then call up a dealership or junkyard. Dealership might make you buy the whole tailight from them though cause they might not stock just the harness. good luck.
Originally Posted by hubjunky1
Easy, go to newlexusparts.com, you need to order the rear light pigtail, its like 20 bucks, I had to get the same part when I upgraded my tails.
